Tractor Talk Discussion Forum
O.T. brake lights don't work, turn signals do?
Dave H. (CO)
05-19-2008 09:46:36
I have a 1998 chevy k1500 truck, and this weekend I borrowed a trailer that had loose wires in the connector. My fuses blew for both my brakes and turn signals. I replaced both fuses. Now my turn signals work, my hazards work, my third brake light works, but the brake lights at the back don"t. (Yes, it"s the same filament as the turn signals) I have a relay under the hood that says "brake lamp relay". Could this only control the lights at the back and not the third brake light? I"d like to get this fixed soon so I can go get my brush hog from the welding shop. (Yes, it"s somewhat tractor related...)
Thanks in advance.
Leland
05-20-2008 00:41:09
 Re: O.T. brake lights don't work, turn signals do? in reply to Dave H. (CO), 05-19-2008 09:46:36
check the fuses under the hood your problem may lie there ,it's such a pain anymore to try to solve any vehicle problem
bradk
05-19-2008 14:16:17
Wiggle the turn signal switch while stepping on brake pedal.If the brake lights come on or flicker,the multi-function switch is junk.Replaced many.
Dave H. (CO)
05-19-2008 14:47:24
 Re: O.T. brake lights don't work, turn signals do? in reply to bradk, 05-19-2008 14:16:17
Thanks all. I"ll go through some more trouble shooting tonight. I"d like to think it"s not the $150 switch. Does the steering wheel need to be pulled to get to it? It has a tilt wheel and airbag if it matters.
bradk
05-19-2008 18:37:04
 Re: O.T. brake lights don't work, turn signals do? in reply to Dave H. (CO), 05-19-2008 14:47:24
Steering wheel doesn"t have to come off.Disconnect battery,remove upper and lower column covers,lower knee bolster(below column)to get at elec. connector.Take careful note when removing unit and install same way.
You"ll need a torx socket bit#20.
Dave H. (CO)
05-20-2008 06:37:27
 Re: O.T. brake lights don't work, turn signals do? in reply to bradk, 05-19-2008 18:37:04
Thanks for the info. Doesn"t sound hard at all. Last night I wiggled the turn signal and nothing happened. Due to the price difference and ease, I"ll replace the relay first, then move on to the switch.
John M
05-19-2008 13:53:09
Did the same thing on my Z71. I think its the AC compressor relay is the same size relay as the brake light relay. Swap them and see what happens.
Roy in georgia
05-19-2008 13:15:12
you may have another fuse you are missing I know I have found them in both under the hood and dash under hood mostly for trailer and dash for vehicle.
IH2444
05-19-2008 12:58:00
fuse ?
ScottyHOMEy
05-19-2008 10:23:41
Is it on the truck or on the trailer that you don't have brake lights? Are your truck and trailer lights on different circuits with relays between them?
Dave H. (CO)
05-19-2008 10:52:47
 Re: O.T. brake lights don't work, turn signals do? in reply to ScottyHOMEy, 05-19-2008 10:23:41
The problem is on the truck. I've used this trailer before and it's been fine. The problem was that a wire came loose in the trailer side connection and touched the other connectors.
LP gas only
05-19-2008 10:09:15
I had a buddy's car do that once. It was the turn signal switch in the colum.
Gary
Dave H. (CO)
05-19-2008 10:15:16
 Re: O.T. brake lights don't work, turn signals do? in reply to LP gas only, 05-19-2008 10:09:15
The turn signals still worked in his situation?
Bob/Ont
05-19-2008 10:54:34
 Re: O.T. brake lights don't work, turn signals do? in reply to Dave H. (CO), 05-19-2008 10:15:16
The power to the brake lights usually goes through the turn signal switch. Signal in center power goes to both brake lights. Signal Left and power goes only to the Right brake light. Signal Right and the power goes only to the Left brake light. That allows the turn signal to flash with brakes on. Short might have burned out signal switch.
Later Bob
Dave H. (CO)
05-19-2008 11:12:07
 Re: O.T. brake lights don't work, turn signals do? in reply to Bob/Ont, 05-19-2008 10:54:34
I don't like that train of thought! Is there any way to check the turn signal?
