Tractor Talk Discussion Forum
2870 Case Tractor
Roger Gwin
05-19-2008 16:32:24
I just bought a 2870 Case tractor. Clutch 2 in the powershift has a bad leak and needs repaired. What is the best way to get to the unit ? Pull the engine or can it be done from the back ? I hope someone can advise me because there are very few in the area. Thanks
NHBoyd
05-19-2008 17:03:55
 Re: 2870 Case Tractor in reply to Roger Gwin, 05-19-2008 16:32:24
You will have to pull the engine. It would be best to come up with a service manual.
c.hess
05-19-2008 18:47:51
 Re: 2870 Case Tractor in reply to NHBoyd, 05-19-2008 17:03:55
There are others better informed but just looking at diagram on case web site it looks similar to 4690 an on that one you need a stand that mounts under engine(large 4 point) an than you can disconect all lines an remove bolts on frame- disconect at bell housing an roll forward. Dont even have to remove radiator or hood on 4690.That is brief description you will do.Case dealers had special stand avaible.
Roger Gwin
05-20-2008 06:51:28
 Re: 2870 Case Tractor in reply to c.hess, 05-19-2008 18:47:51
I wondered about leaving everything together as I was looking thingss over. Good idea.
Roger Gwin
05-19-2008 17:21:13
Thank you for responding. I will try to locate a service manual. Any suggestions?
