Tractor Talk Discussion Forum
38 steel rear rims for a 1951 JD B
cdm
05-20-2008 04:44:32
Can anyone tell me where I could find a set of pressed 38" steel rear rims for a 1951 JD B? I am looking for friend who needs to get tractor weight dowwn for pulling.
Thanks in advance
2x4
05-20-2008 14:08:16
 Re: 38 steel rear rims for a 1951 JD B in reply to cdm, 05-20-2008 04:44:32
What does it mean "pressed"? How many lug holes does it have? I have a pair of rims & tires -9 hole, 38 inch from a Seaman Pulvimixer. $300 in west virginia.
2x4
05-21-2008 16:05:05
 Re: 38 steel rear rims for a 1951 JD B in reply to 2x4, 05-20-2008 14:08:16
these are pressed steel then
Leroy
05-20-2008 18:00:21
Normal wheel is a heavy cast wheel center with a seperate rim. the disk wheel is a cheaper setup and is made the same as the front wheels. Would have to check parts book to find out if hubs are same but I am thinking not.
