Tractor Talk Discussion Forum
starter
oldsterGA
05-21-2008 03:34:08
What happens to a 6 volt starter if it is used on a 12 volt system? Thanks much. God bless. Phil
36 coupe
05-22-2008 04:25:43
 Re: starter in reply to oldsterGA, 05-21-2008 03:34:08
Broken starter drives are common.Motor runs at twice the speed when the gear engages the flywheel teeth.
Walt davies
05-21-2008 10:30:19
I have been using mine on my Case LA for several years now crank the "H" out of it sometimes with no problem what so ever.
Walt
old
05-21-2008 07:50:05
Well about all that happens is they get hotter faster if you let them spin to long. A 6 volt starter has heavy wires in it because lower volts means higher amp to do the same job
jose bagge
05-21-2008 03:52:47
we used to do this all the time with VWs that we converted to 12 volts, since the starter swap required a flywheel change. 12V really made that 6v starter fly- not a bad thing sometimes!
Paul from MI
05-21-2008 03:49:37
Not much, except that it will turn a lot faster. I've used one on my JD A for 15 years, 6V starter on 12V. No problems. What hurts them is heat, so don't crank the engine a long time without letting the starter cool down. Starters are not designed to run continuously, no matter what voltage.
Paul
