Tractor Talk Discussion Forum
starts runs then dies 15 minutes later
Bubba Gamble
05-21-2008 07:08:22
1954 Jublee starts and runs good not great but runs i start shreading it will run for it for about 15-20-minutes then dies, it takes about 30 minutes to cool then it will run for about, 10 minutes it does this over and over. i have changede all the eltronics and no change. i have pulled the plugs when it dies to see if filled with oil or something else but nothing.
Jim Bevins
05-21-2008 18:43:29
 Re: starts runs then dies 15 minutes later in reply to Bubba Gamble, 05-21-2008 07:08:22
I had a similar problem like that one time,but mine was Fuel.Had a tree leaf in the Fuel Tank that kept getting sucked into the fuel pickup line inside the Tank and blocking off the Fuel.
How that Leaf got in there,I don't know!
El Toro
05-21-2008 13:05:28
You need to check for fire to the plugs asap when it quits running. If there's no fire replace the coil. Hal
soundguy
05-21-2008 11:04:10
when she dies, check the spark.. if it has spark.. look at the fuel.. perhaps even tank vacume.
if no spark.. jumper around the key switch.
post back
soundguy
ozzman
05-21-2008 10:31:28
Bubba,
I have a 1953 jubilee and had the same problem. I went on this forum and got all the same answers started with fuel so I took of the copper fuel line and replaced it with temporary clear hose so I could see if it was a fuel problem, it wasent.Then everyone started saying it was the coil,it wasent. So I started looking deeper and when I took the point and condenser mounting plate off I found that the wire going to the points was old and frayed so I replaced it and the problem went away. Hope it works for you.
2x4
05-21-2008 15:58:28
 Re: starts runs then dies 15 minutes later in reply to ozzman, 05-21-2008 10:31:28
had the same thing happen with a pickup truck. Like to drove me crazy. The wire shorts out when it gets hot & moves a tiny fraction.
ozzman
05-21-2008 09:49:13
Try pulling the distributer cap and take off the points and condenser plate and check the wire that is below that plate make sure it has good connection and is in good condition
NawlensGator
05-21-2008 09:36:31
Been there, done that. COIL
:RIVIR
05-21-2008 08:59:19
YUP check the coil
JDknut
05-21-2008 08:57:53
Looks like you might be barkin' at a coil.
Jerry/MT
05-21-2008 08:44:07
When it dies check the spark. If you don"t have any, I"d suspect the coil or the key switch. Is your electrical system a 6V or a 12V? If it"s a 12 V do you have a real 12V coil like NAPA IC-14SB? If you don"t do you have a resistor in the the primary ignition circuit? These coil are limited to 4 amps max current and if you have a 6V 1.5 ohm coil on a 12 V system, you"ll be putting about 8 amps through the coil and that will cause an overheat of the coil. Key switch can have high reisitance and cause a similar problem. When it dies on o you and has no spark, jumper around trhe key switch and see if it will start. If it starts when you jump the key switch, then the key switch will need replacement.
If you have a good spark when it dies, then it"s the fuel system that you should look at, Check fuel deivery to the carb and make sure the tank vent is clear.
MF Poor
05-21-2008 08:19:50
Coil
Allan In NE
05-21-2008 08:29:39
 Re: starts runs then dies 15 minutes later in reply to MF Poor, 05-21-2008 08:19:50
Sounds like a bad coil for sure.
Allan
tlak
05-21-2008 08:13:58
Check coil and condenser,and ignition switch, breaking down after hot then cools and runs again. Check for rust in the fuel tank, sets and seeps past the rust and fills the fuel line allowing it to run again.
old
05-21-2008 07:54:56
Well to start with they didn't make a Jubilee in 1954 only 1953. If in fact its a 1954 then its an NAA. Almost the same tractor other them hood emblems. As the others said maybe the gas tank vent. If taking the gas cap off does not fix the problem check for spark you may have a bad condenser
Gerald J.
05-21-2008 07:30:23
Plugged gas tank vent. New cap? Original cap was vented.
Gerald J.
RustyFarmall
05-21-2008 07:29:03
Next time when it dies, remove the fuel tank cap and listen for "whooshing" sound. If you hear that sound, it indicates that the vent for the fuel tank has become obstructed, which creates a vacuum, and fuel cannot flow to the carburetor.
