Tractor Talk Discussion Forum
Tractor smells
agnel matt
05-21-2008 17:00:48
Dear Lads I have an old diesel 40HP International tractor that was on a log splitter all fall and than stored all winter in a heated shed. Now this spring when it runs there is a smell of smoke and black smoke comes out of the muffler when I give it gas but it is not burning oil. Also it is a bit harder to start. Should I be worried?
Goose
05-21-2008 20:21:16
 Re: Tractor smells in reply to agnel matt, 05-21-2008 17:00:48
My D19 diesel usually is parked during the coldest several months of winter. With or without fresh fuel, when it's started up in the spring it usually needs to work for a couple of hours before it smooths out and runs decent again.
Mark - IN.
05-21-2008 19:20:19
Most have hit it pretty good, but also could be rich on the fuel. Intake not clogged as well and running rich? Just a thought since was running well when you parked it. You aint missing a barn cat and maybe see a cat's tail hanging out of the air cleaner? Well, neighbor's cat?
And by the way, I smell when I run, but that's another issue.
Mark
RustyFarmall
05-21-2008 18:09:13
Diesel engines do not like to be treated easy. Everything gets all sooted up inside. You need to start that engine, warm it up a bit, and then work the ever-livin' you know what out of it. That tractor will thank you.
joe etx
05-21-2008 18:06:20
buy cheapes quart or what ever of new vegetable oil and poar in tank smells good and engine runs good.
ErnieDD
05-21-2008 17:31:28
Mouse nest in the exhaust?
Roy in georgia
05-21-2008 17:05:23
sounds like it is overloading on gas
RayP(MI)
05-21-2008 17:27:13
 Re: Tractor smells in reply to Roy in georgia, 05-21-2008 17:05:23
DIESEL! If you"re sure the engine is intact, replace old fuel with fresh, and try working it for a couple hours. See if it doesn"t clear up on it"s own.
Gary from Muleshoe
05-21-2008 17:05:12
Was the fuel drained before storing it? Sounds like it is running to rich or possibly bad fuel. Try draining the tank and putting fresh fuel in, this may clear it up.
agnel matt
05-21-2008 17:35:42
 Re: Tractor smells in reply to Gary from Muleshoe, 05-21-2008 17:05:12
okay I did not drain the tank or add fuel I will try that
Bendee
05-22-2008 01:40:27
 Re: Tractor smells in reply to agnel matt, 05-21-2008 17:35:42
Check the fuel mixture.Too rich.
Bob Farrell
05-22-2008 06:03:15
 Re: Tractor smells in reply to Bendee, 05-22-2008 01:40:27
Totally disconnect the air supply from the engine. Start it up. Work it for 30 minites. If it stops smoking you have something obstructing the air supply. One year old fuel is NOT your problem. Let us know. bob farrell
