Tractor Talk Discussion Forum
OT- Water heater question
Jrry
05-22-2008 05:40:01
I have a 40 gallon electric water heater that is about 4 years old. It is rated for ten year life. Recently it has begun shutting off during the day. I can push the reset button that is in the door by the top eliment and it will work for about 12 hours and shut off again. We have noticed that the water temp is getting much hotter than it used to. I turned the setting down but it still gets just aas hot.I thught it was an electrical short but i had an electrician check it out and he said no problem there. He thought it may be the thermostat. If the problem is the thermostate not working properly then how does it determine that it needs to shut off? If is is the thermostat are they difficult to replace or should I just replace the water heater? I know this is off topic but there are knowledgeable people here about most subjects. thanks for any help, Jerry
buickanddeere
05-22-2008 11:41:31
 Re: OT- Water heater question in reply to Jrry, 05-22-2008 05:40:01
Get a new electrician.
An element is grounding out and putting full time 120V through part of the element, bypassing normal thermo control until the overtemp thermo trips.
Imagine what would happen without a properly bonded and installed grounding system. There would be somebody shocked, injured or dead after touching the system or showering.
HENRY E NC
05-22-2008 10:07:40
Most hot water tank thermostats had a thermodisc cut off which shuts it off should the thermostat fails to shut the electric off.. Change one or both of the thermostats and you will be good to go. Henry
Walt davies
05-22-2008 09:09:55
check your warranty and see if its covered before spending hard earned money.
Walt
Duner Wi
05-22-2008 08:09:23
When I have trouble like yours it is my lower element. Last one I put in was called a Sand Hog I think and has lasted many years.
Bob
05-22-2008 08:02:08
It's either a thermostat or an element.
Thermostats can stick.
OR, if an element (usually the lower one) fails in such a way that part of the element becomes grounded or exposed to the water, the heater will SLOWLY overheat... 'til the limit switch trips.
This happens because the thermostat only breaks one "leg" of the 240 Volt line. The element is ALWAYS connected to the other "leg", 120 Volts, even with the thermostat open, so if there is a short or damage to the element, it will keep heating.
When the safety limit finally trips, it breaks BOTH sides of the 240 Volt supply, so the overheating stops.
KEB1
05-22-2008 07:06:10
Most likely the bottom thermostat. There should be two thermostats, one at the top and one at the bottom. The top thermostat also acts as an overtemp limit and will shut both elements off.
If the bottom thermostat is stuck on, or not making good thermal contact with the tank, it will keep the bottom element on until the water gets hot enough to trip the overtemp limit on the top thermostat. Tripping the overtemp on the to thermostat shuts off both elements, so you have nothing to heat the water until you reset it. 12 hours is probably about how long it takes the bottom element by itself to get the water hot enough to trip the overtemp limit switch.
Its also possible its the top thermostat, but I'd start with the bottom one.
Keith
Ken Crisman
05-22-2008 06:08:40
I'd guess elements first , than bottom thermastat . I had the very same problems . Found the bottom of my tank had about 3" of iron buildup laying around the element . Flushed it out as best I could & then replaced both elements since iron buildup was so bad . Than I decided to go ahead & replace the bottom therastat also . Walla ! My tank ststed to replace the bottom element with a higher element so I did . Boy I have much better hot water now . So check out to see if yours states to do that before buying parts . HTH! God bless, Ken
paridgerunner
05-22-2008 05:53:05
Thermostat's are easy to replace and cheap, I would try to replace them before buying a new water heater, just shut the power off before changing them.
dave2
05-22-2008 05:52:02
Can't be anything difficult (after you get over the "it's a major appliance" intinidation). Check out the tankless heater post a little farther down, someone mentioned a water heater repair kit w/ tstat and a couple of other things. Or, just take the info off the plate and go shopping. While you're playing with a screwdriver, may not hurt to pull the elements out and clean some of the lime off.
Dave
Jim in NY
05-22-2008 18:52:41
 Re: OT- Water heater question in reply to dave2, 05-22-2008 05:52:02
1) Both upper and thermostats must be set the same (usually 120 degrees) (do not set them at different temps for any reason as this is the balancing device(s) for temperature in the tank itself. before this make sure bottom of tank is not full of sediment and flush as necessary via the lower element when removed (first shut off the electric power to the heater and keep it off until the tank is full of water again and air is bled from it via a faucet or the relief valve vent )... then inspect condition of lower elelment (no resistance or very little on an ohmeter if you have one available. I don't think it is a non touching thermal disc because it was okay for some time before the overheating problem began, however it could be bad though... Bottom unit as a whole is where i would start and probably find the problem(s). Remember --- electric off when working on this heater especially when you are draining it and refilling untill entirely full of h2o and all air removed(bled).
