Tractor Talk Discussion Forum
old tractor crank?
Elijah
05-22-2008 09:48:39
Not sure what's it for. Found it lying under a pile of rubble while cleaning out the shop. It is 31.5 inches overall length,has a 7.5 inch jog from the main shaft to the handle,the handle is 4.5 inches long,the whole thing is just over five eighths diameter and has two opposed nubs of one quarter inch about one half inch from the end.I was thinking maybe for a farmall A or B but I'm not sure. Any help would be appreciated as I moved from the country into town and am trying to find the correct home for it. thanks,Elijah
Sam#3
05-22-2008 21:49:44
 Re: old tractor crank? in reply to Elijah, 05-22-2008 09:48:39
With a shaft that long and small I'd think more about a jack handle or the tool to operate the spare tire hoist or a combination of both.
I just measured the shaft on the one in my pickup at 34". It's made in two pieces with a detachable handle.
Elijah
05-23-2008 09:26:52
 Re: old tractor crank? in reply to Sam#3, 05-22-2008 21:49:44
No, I don't think so because it looks just like an engine crank starter. I'm sure that's what it is I just don't know what for.
Maark
05-22-2008 14:05:39
It's a wrench for a International or Farmall Cultivator that fit either a M or H tractor
Maark
05-22-2008 14:07:28
 Re: old tractor crank? in reply to Maark, 05-22-2008 14:05:39
I reread your post,A cultivaor wrench would have a socket on the end.
toomanycases
05-22-2008 11:41:56
Could be a crank for a old truck. Sounds like one that would fit my 48 Studebaker 2 ton.
Walt davies
05-22-2008 11:15:32
Could be for an MG car they had a long crank like that.
Walt
Bob
05-22-2008 11:13:39
If your "just over 5/8" measurement" is correct, that'e awefull small for a tractor crank.
I don't know about a Cub, though!
2x4
05-22-2008 10:53:52
could be a crank for an old power unit. I had a UD-6 Internat'l power unit that started on gas & switched to diesel, that could only be crank started. Ran a sawmill with it for years.
Oldmax
05-22-2008 10:14:35
Could also be a car crank . A Models Fords and later model Cars and trucks had Crank notches in front pulley that would take a crank . But that was only for the brave they were an arm breaker .
I had a 48 Chev truck that had a crank with it .
EWS
05-22-2008 10:01:38
I think that I have been called an "Old Tractor Crank!"
dddl
05-22-2008 10:14:07
 Re: old tractor crank? in reply to EWS, 05-22-2008 10:01:38
better than being called a "cranky old tractor"
