Tractor Talk Discussion Forum
IH 706 Brake Valve
in-too-deep
05-23-2008 07:35:34
Anyone ever rebuilt the hydraulic brake valve on a 706? I've got fluid bypassing the valve and pressurizing the brakes. Is it a real complex job?
mazemeister
05-23-2008 18:26:51
 Re: IH 706 Brake Valve in reply to in-too-deep, 05-23-2008 07:35:34
i had a similar problem on an 806. there's not much you can do to the valve other than take it apart, look for something obviously broken, replace o-rings. as i recall, my problem was a broken screw that goes into one end of the spool and compresses a spring. when you take it apart, pay attention which spool goes into which hole- R and L are not the same.
LBSMJS
05-23-2008 16:02:33
No theres not much to goof up in that valve,but before you take it off check the ajustment.Besure the rod that hooks to the pedel is return all the way & that the pedel moves free.
