Tractor Talk Discussion Forum
Why is it that a 30 minute job
old
05-23-2008 11:47:04
takes 2 or 3 hours and one you figure will take you an hour ends up being 15-30 minutes. I went to change the thermostat in my Allis C which should have been a 30 minute job if all went right but no bolts had to brake and then had to be welded on etc to remove them. And then also yesterday I took off an shield from a NH 68 baler to put in on my NH271 and figured it would take me around and hour to do and it took about 30 minutes.
Bud Sather in MT
05-24-2008 13:38:25
 Re: Why is it that a 30 minute job in reply to old, 05-23-2008 11:47:04
Those oil filters will come off a lot easier if you never put any oil or grease on the gasket and be sure that the base where attached is wiped clean and dry. Bud
Bruce Hopf
05-23-2008 18:49:09
I don't have the answer for your question. I'm still trying to figure out why in the wide world of sports, it takes 4 to 5 hours to do a 1/2 hour job. Recently I changed the oil in my future wife's Chevy Blazer, and it took me 4 hours to remove the idiotic oil filter. I had to remove the guard under the engine to be able to put a fair sized pipe wrench on it to the oil filter to get it to budge. The idiot before me must not have put any thing on the rubber of the oil filter, or used a tiny bit of oil on it. I always, always put a dab of grease on the rubbers on the oil filters, so that they come off a lot easier. You can almost turn the filters off by hand. No Fuss No Muss.
Bruce. Sorry for venting.
dave guest
05-23-2008 18:00:16
George, you are lucky to be married to a smart cookie.
chvet73
05-23-2008 16:31:03
I can't give you an answer but I bet the same thing happens to all of us.
GeorgeH
05-23-2008 15:56:17
My wife says I don't know how to estimate..... ..
omahagreg
05-23-2008 15:23:05
Went to change the oil on a 318 plymouth one evening-that filter was supposed to be turned 1/4 turn after contact, by hand. WELL-it must not have been-we had to destroy the filter to get to the base, so we could loosen it! Took us 4 hours, if I recall. Greg
Bob
05-23-2008 12:40:54
"Everything always takes longer than it does!"
ScottyHOMEy
05-23-2008 12:21:56
Taylor's Law. "Murphy was an optimist."
RVS
05-23-2008 12:15:44
Murphy's Law the old saying crap happens. Happens too us all,well at least to me it does
Ron
Janicholson
05-23-2008 12:04:35
Old, reality never looks ay a clock. Humans do so at their own risk. JimN
Janicholson
05-23-2008 12:04:23
