Tractor Talk Discussion Forum
Radiator hose leak: puzzled
tractormiallis
05-24-2008 10:43:29
My lower radiator hose on my AC WD was leaking around the top and bottom where it is clamped. It had been sealed with permatex as a gasket before, about 2 years ago. Now I took it apart, resealed it 2 weeks ago with new permatex, and now it has decided to leak again. It the antifreeze eating away at the sealant? The hose does not look bad. Some other sealant to use?
Janicholson
05-25-2008 07:24:06
 Re: Radiator hose leak: puzzled in reply to tractormiallis, 05-24-2008 10:43:29
If the hose is bad on the inner liner, it will often leak through the fibers and appear to leak at the metal interface. JimN
LenND
05-24-2008 14:51:14
Would JB weld work to fill in the deep pits in the metal? Just asking, but if it was cleaned up real good first shouldn"t it work?
jose bagge
05-24-2008 12:32:54
I've run into this before with old castings. I remedied it by double clamping (two hose clamps on each end)
2x4
05-24-2008 11:30:11
maybe the hose itself is bad. I'd replace it.
old
05-24-2008 11:08:25
How ruff is the surface of the pipe its on?? Or maybe theres a crack in the pipe. I've seen both of those cause problems. My self if I have a problem like that I use silicone sealer and then let it sit a good hour or 2 before putting any coolant in to the system so it has tie to dry
