Tractor Talk Discussion Forum
Post for What a cry baby reply
NCWayne
08-03-2008 15:57:38
I normally try to keep my posts and replys non personal but you crossed a line in your response calling me a "jackleg with a hammer and a cresent wrench and vice grips". I'm 40 and have worked on equipment all my life. I grew up working on local farm equipment and heavy equipment with Dad, spent 6 years in the Navy (got out an E6 based soley on what I knew not who I blew) here I work on steam turbines, 1200 psi boilers, heat exchangers, 4 different types of air compressors, pneumatic systems, pumps, valves, etc. Then spent about 6 years after getting out doing industrial maintenance, and working on equipment on the side, before going into it full time about 10 years ago. I might be a jackleg but three years back I did nearly a complete rewire of an AC125H American crane using nothing but an sorry, partially incorrect factory schematic (yes it was drawn wrong from the factory) and plenty of phone calls to the factory rep. If I hadn't had the industrial experience I would have been lost there because it had all Cutler hammer stack type switches. Try using a schematic that's not the best in the world anyway and figuring all that mess out after someone who obviously didn't know anything about wiring had been messing with it and had dozens of wires crossed up until it would only function partially in one of 5 modes, and that because they lucked out and had the mode selector swiches stacked wrong so they all opened their respective circuits at the same time. I never claimed to be the best but when it comes to troubleshooting I am damm good because I take the time to understand how the system is supposed to work so I know where to start looking and what to look for. Computer be dammed, the brain is the best tool for troubleshooting ever invented. Don't believe it I'll be glad to give you numbers and you can call and you can ask any one of the customers that I've repaired machines for over the years and ask them why they still call back when they have problems. Dad and I don't advertise but we stay busy by word of mouth alone, and that doesn't happen if your a jackleg. Based on what I see in the field if I had to make an assumption here I'd say obviously you couldn't troubleshoot your self out of a wet paper bag or you wouldn't have made the less than enlightened comments you did saying basically that trouble shooting anything was as easy as plugging a computer in and changing a part. So, enlighten me, what was the last piece of newer or older equipment you did any kind of troubleshooting on and how long did it take to figure out what was wrong and repair it, not just guess and change a part? That was my biggest complaint, you can get a machine running nowdays and not feel like you really "repaired it" because the only choice you had was to replace a part and you never really know what was wrong beyond a trouble code that disappeared. NO, I don't have the CAT softward for the machine I was working on and didn't need software to do the tests I was doing. The machine is nearly 10 years old and the only "software" needed is imbedded in the machines computer. If I did have "software" I could have plugged in my laptop and the machines computer would tell my laptop exactly what it shows on the machines display, code for code, nothing more, nothing less. If you think the dealerships guys could do any better spend a little time in the field with me and listen to the customers talk about the many "technicians" from the dealerships that don't know their head from a hole in the ground. Many can plug in a computer and change a part but they can't really troubleshoot to save them because they don't have a clue how the machine's different operate or what they are supposed to be doing in the first place. I know several really good guys at the a couple of the dealerships and they have no problem telling me the problems they see on and swapping info with me just as I do with them. Us real mechanics are a fairely small community and we have no problem sharing info when needed on problems we see. You see and learn something new each and every day and when you see someone with the same problem you help and in the end we all learn. Problem is most don't want to learn, the want to plug in and change parts.... Every dealership guy I know would tell you the same thing I'm telling you except for the fact that they can't really talk bad about their respective brands to a customer and expect to keep that customer using their machines or possibly lose their own jobs when their boss found out about their talking trash about their brand. All that aside, and onto the machine you seem to think I tackled with a hammer and a cresent wrench and vice grips and you seem to know how to work on. In lieu of software they have a service manual for the 320B that's nearly 6 inches thick and it's chock full of troubleshooting flow charts for the codes the computer spits out. One code, no problem, several codes maybe no problem. Get beyond that and you don't always know if one problem is causing another or if you replace the part to clear one code if another is gonna come, or anything beyond what the machines computer, the service manual, and your test meter can tell you. All I can tell you is if you can figure out how to climb inside one or more of a hundred different wires and figure out which two are shorted and exactly where in the harness the short is, or exactly what component or components are throwing the bad signal, based on a code which can have half a dozen different causes you'll be THE BEST MECHANIC EVER. If you can master that feat and write a book for all us jacklegs I for one will gladly buy one, and recommend them to all my dealership buddies also, and you'll soon be a millionaire and can finally quit going out in the heat and the cold, the dust and the mud, and sit back and laugh at the rest of us. Man I wish I could do that sometimes. You think terchnology saves fuel, maybe it does in some cases. Ask our customer that stopped using a 9570 Northwest friction crane for draglining and started using a newer Linkbelt. The NW's Murphy, using twenties/thirtys technology moved X amount of material a day using 30-40 gal of fuel. The Linkbelt moved less than X, slightly more than half we were told, and used 130 -140 gallons a day. That came straight from the operator whom we've known for nearly 8 years now, and his only praise for the newer machine was that it had A/C. Still even $10000 in fuel saved over years by technology -vs- $7000 spent in parts and another several thousand spent in labor troubleshooting, $14,000 last year on a new engine, seems to me the fuel savings due to electronics just don't add up to the cost of replacing those electronics unless the machinecan run for ALOT of years completely trouble free. As for regressing back to the '80's, many of the things being tried on the new machines had their roots in the 70's and 80's. Electric over hydraulic controls, CAT with their new AC electric driven D7 due to appear in '09, and I'm sure their are others I could think ofgiven time. They didn't work then becuase of technology hadn't progressed far enough, and they are having problems now because the technology is still now far enough along to be as bullet proof as is being claimed. Spend time in the field and really listen to what is being said vs just what you see in the trade publications coming from the corprate "suits" and you'll soon have a very different view of technology. But that's just the ravings of one of us jacklegs..... .
NEsota
08-03-2008 18:18:33
 Re: Post for What a cry baby reply in reply to NCWayne, 08-03-2008 15:57:38
Wayne, have you tried writing things up on your word processing program, punctuating, spell checking and then moving the content over to the YT box? You have good thoughts we do not want their content getting lost in transit.
MN Joe
08-03-2008 17:35:39
I have to say --- your sure long winded --- now tell me what State you work in and what Licenses you hold to work on High Pressure ????? ??
Roberto T
08-03-2008 17:40:04
 Re: Post for What a cry baby reply in reply to MN Joe, 08-03-2008 17:35:39
How do you feel that is any of your business?
How much money do you have in your checking account?
RodInNS
08-03-2008 18:07:35
 Re: Post for What a cry baby reply in reply to Roberto T, 08-03-2008 17:40:04
The thought crossed my mind that he might want to hire him?? That would make his licence relevant... Perhaps more for a private conversation tho.
Rod
Roberto T
08-03-2008 17:39:38
Hoe do you feel that is any of your business?
Lanse
08-03-2008 17:44:18
 Re: Post for What a cry baby reply in reply to Roberto T, 08-03-2008 17:39:38
Roberto T is just a little upset because he missed spongebob today.
Just dont let his stupid little comments get to you. Wayne, you are for real, this little jerk isnt.
IaGary
08-03-2008 20:11:25
 Re: Post for What a cry baby reply in reply to Lanse, 08-03-2008 17:44:18
Lanse either you or Roberto have to get a different IP number.
I get confused and don't know which one of you is talking.
Gary
Amarillo Doug
08-03-2008 17:20:23
AMEN Wayne.After working as a heavy equipment mechanic for 25+ years I agree with you 100%.Nothing irritates me more than some a** who doesn't know his a** from a hole in the ground try to tell me how to troubleshoot a piece of machinery by plugging into a durn computer when in some cases the machine is strictly mechanical and DOESN'T even have a computer on it!
Buzzman72
08-03-2008 17:03:52
Wayne, I agree with you 100%. All this electronic crap, sooner or later, will come back to haunt us. My experience is on the car/truck side of things, and while "drive-by-wire" electronic accelerator systems are in their early days, I'm waiting for "steer-by-wire" to come, as the manufacturers say it will. Without a mechanical backup, I can forsee a lot of potential liability problems when these systems foul up...as all systems eventually do.
Back in the 1980's, we wondered what we'd do when some of those elementary [by today's standards] ECM's became obsolete...and now we know: you park it and get something else. When it's a piece of equipment that costs hundreds of thousands of dollars, you begin to appreciate the old stuff. But there's nothing that you or I can do about it, so I hope that venting now and then is as therapeutic for you as it is for me.
tlak
08-03-2008 16:48:49
Thought you were talking about the whiners on here that don't post anything till there's an O/T, then instead of moving on, they read it and whine about and report it to the mods, who probably delete it to stop their whining. My mistake.
Two Dogs
08-03-2008 16:44:46
Wow!! I'm impressed!! Can I get you to father my next child?
Tractor,Tractor
08-03-2008 16:42:49
Finally someone else who understands that ya gotta know how it is suppose to work before you can fix it right. Right on Bro.
bison
08-03-2008 16:17:46
wayne,his name says enough,no need to justify yourself to the likes of him.Don't get yourself riled up.
But by the way you go on and on,makes for hard reading though.
NCWayne
08-03-2008 16:20:54
 Re: Post for What a cry baby reply in reply to bison, 08-03-2008 16:17:46
See my reply to the first guy who replied. My posts never show up with paragraphs so I quit trying. Tried it with my reply to him and it still all runs together. Have any ideas what might be wrong?
Lanse
08-03-2008 16:21:58
 Re: Post for What a cry baby reply in reply to NCWayne, 08-03-2008 16:20:54
try modern view
Roberto T
08-03-2008 16:06:35
Perhaps you could format your post using paragraphs. It would make it much easier for us to read and understand.
NCWayne
08-03-2008 16:17:44
 Re: Post for What a cry baby reply in reply to Roberto T, 08-03-2008 16:06:35
Sorry. Seems in the past when I've tried using paragraphs, for some reason, they don't show up as such when they post to the site, so I stopped even trying to type them that way. Of course I could use the excuse that I'm just a jackleg anyway so I really don't know any better...LOL I'll try it with this post and see what happens.....maybe it'll work, maybe not. I did have some computer problems several years ago, about the time I found these boards, and have had a major malfunction and gotten it repaired since. Maybe it'll work, maybe not, we'll see. For all that want to complain about several mispellings, etc I apologize again. I hit post instead of back and didn't have a chance to make corrections.
NCWayne
08-03-2008 16:19:16
 Re: Post for What a cry baby reply in reply to NCWayne, 08-03-2008 16:17:44
Nope, previous post written paragraphs and all and it still posted all lined up and run together so it's not my fault. Blame the computer.....
F-350
08-03-2008 19:16:15
 Re: Post for What a cry baby reply in reply to NCWayne, 08-03-2008 16:19:16
My computer used to do that too.
Randy-IA
08-03-2008 18:43:40
It runs everything together from my computer also unless I hit " enter " two or three times between paragraphs .
Like this , I hope . But that makes for really long posts . ...Randy
Spook
08-03-2008 17:47:17
I have the same problem. It happens when I email sometimes also.
Roberto T
08-03-2008 16:24:15
I wasn't blaming you. I was offering a friendly suggestion.
