Ford 600 Serial Numbers
Lee
03-22-1998 15:48:33
Help!
I recently became the owner of a Ford 600. How can I tell "exactly" which model (ie 640, 650, etc) and the year it was made?
I found the following numbers on it: On the left side, just behind the floorboard: NCA 04024 ( the leading zero might be my imagination as the numbers were hard to read...)
On the right side just in front of the floor board were two rows of numbers. The first row was: NCA 7006B and the second row appeared to be 63F ( they were hard to read too.)
Any and all advice and sugggestions would be appreciated.
Cheers, Lee
John H.
03-26-1998 07:57:18
 Re: Ford 600 Serial Numbers in reply to Lee, 03-22-1998 15:48:33
: Help!
: I recently became the owner of a Ford 600. How can I tell "exactly" which model (ie 640, 650, etc) and the year it was made?
: I found the following numbers on it: On the left side, just behind the floorboard: NCA 04024 ( the leading zero might be my imagination as the numbers were hard to read...)
: On the right side just in front of the floor board were two rows of numbers. The first row was: NCA 7006B and the second row appeared to be 63F ( they were hard to read too.)
: Any and all advice and sugggestions would be appreciated.
: Cheers, Lee
Dan's right. I just bought a 640 Ford, and had some trouble finding the numbers until someone told me. The serial number is on the top of the transmission, on a flat surface, just aft of the starter. Mine has "620" and underneath the serial number (I have 130632, built in 1957). Lee, write me and we can compare notes on these things.
Dan
03-22-1998 21:08:06
: Help! :
Don't panic, man! Those numbers you quote, are they stamped or cast? Sounds like you are reading casting numbers. The actual tractor serial number is stamped, not cast. As Far As I Know, the serial number location on the 600-series was on the left side of the transmission housing to rear of starter motor on a semi-vertical flat spot.
Year of manufacture is easy-
Year serial #
1954- 1
1955- 10615
1956- 77271
1957- 116368
Dan
glauber
02-27-2000 14:35:55
 Re: Re: Ford 600 Serial Numbers in reply to Dan, 03-22-1998 21:08:06
: : Help! :
: Don't panic, man! Those numbers you quote, are they stamped or cast? Sounds like you are reading casting numbers. The actual tractor serial number is stamped, not cast. : As Far As I Know, the serial number location on the 600-series was on the left side of the transmission housing to rear of starter motor on a semi-vertical flat spot.
: Year of manufacture is easy-
: Year serial #
: 1954- 1
: 1955- 10615
: 1956- 77271
: 1957- 116368
: Dan
Lee
03-23-1998 19:41:32
: : Help! :
: Year serial #
: 1954- 1
: 1955- 10615
: 1956- 77271
: 1957- 116368
: Dan
Dan,
Thanks for the response. The numbers I referred to were either immediately in front of or behind the running boards on the left and right side respectively. They do appear to be cast into the metal as opposed to "stamped" I will check them out and look for the serial number next to the starter area on the transmisison housing. Know of any good web sites where I can learn more about this machine??
Cheers,
Lee
Ahmed
07-10-2000 04:41:06
 Re: Re: Re: Ford 600 Serial Numbers in reply to Lee, 03-23-1998 19:41:32
: : : : Help! :
: : Don't panic, man! Those numbers you quote, are they stamped or cast? Sounds like you are reading casting numbers. The actual tractor serial number is stamped, not cast. : : As Far As I Know, the serial number location on the 600-series was on the left side of the transmission housing to rear of starter motor on a semi-vertical flat spot.
: : Year of manufacture is easy-
: : Year serial #
: : 1954- 1
: : 1955- 10615
: : 1956- 77271
: : 1957- 116368
: : Dan
: Dan,
: Thanks for the response. The numbers I referred to were either immediately in front of or behind the running boards on the left and right side respectively. They do appear to be cast into the metal as opposed to "stamped" I will check them out and look for the serial number next to the starter area on the transmisison housing. Know of any good web sites where I can learn more about this machine??
: Cheers,
: Lee
Mohammed Saha
08-22-2000 14:20:15
 Re: Re: Re: Re: Ford 600 Serial Numbers in reply to Ahmed, 07-10-2000 04:41:06
I look for sereial number of Windows Me
aloncio alves miranda
12-20-2003 18:18:50
 Re: Re: Re: Re: Re: Ford 600 Serial Numbers in reply to Mohammed Saha, 08-22-2000 14:20:15
gortaria do serial do xadrez master
arun
12-12-2002 17:08:12
give the list of sereial no.s
u have, do u have pc cillin 2002 sereial no if so mail to me.
bye,
arun
raja
09-23-2001 06:54:01
speed connect 4.01
serial number send..... ... thank u
Ole BoB
03-27-1998 18:04:15
Ok ,late 1964 saw the introduction of the 600 series.
The 650 which I have is a 5 speed with a live PTO
The 640 is a 4 speed without live PTO like the jubilees
Mine was made in 1957 .I was told the first nu 6 is
600 series the 5 means 5-speed and the 0 means something But I can't remember Ole BoB: : : : Help! :
: : Year serial #
: : 1954- 1
: : 1955- 10615
: : 1956- 77271
: : 1957- 116368
: : Dan
: Dan,
: Cheers,
: Lee
