Serial# farmall M
Randy
04-08-2000 19:39:12
I have a 1950 M serial# FBK 217278X1. What does the X1 stand for? I'm practicing my restoring skills on this tractor as I also have a 40 M that I hope to do a better job on.
The Red
04-09-2000 05:52:48
 Re: serial# farmall M in reply to Randy, 04-08-2000 19:39:12
Randy x1 stands for gasoline. Over in the left tool bar under community select Forums and then select Farmall & IHC and join us.
RANDY
04-09-2000 08:16:40
 Re: Re: serial# farmall M in reply to The Red, 04-09-2000 05:52:48
Thanx to the red for the info. say if your still out there, I have an M # FBK 24508 which I think is a 1940. could that tractor have burned fuel other than gas? the reason i ask is there is a hole in the hood for filling like a pony tank. but all the hardware, ponytank, fuel lines,etc.
are not ther. Maybe its just not the original hood.
derek schwarting
10-16-2005 07:35:17
 Re: Re: Re: serial# farmall M in reply to RANDY, 04-09-2000 08:16:40
i also have a ih farmall with the serial number fbk iam wondering the same thing but for sure the tractor is a 1940 same as mine.if anyone knows anything about please tell us.the serial on my tractor is fbk 7827.
The Red
04-09-2000 10:25:46
Sorry for not responding earlier. I was out at my JD 4400 combine getting ready to move it 4 miles through Indianapolis. That should be interesting!
Guy Fay could tell you the answer right out but since it is lacking the x1, I would guess that you had a duel fuel to start with even though the little tank, lines and probably the two line fuel strainer are gone.
Randy
04-09-2000 17:43:22
 Re: Re: Re: Re: serial# farmall M in reply to The Red, 04-09-2000 10:25:46
Thanx the red for the additional info. I'm new to the internet and this web site so i'm wondering who is guy fay ? Would have been back sooner but I was out in the field harvesting a bumper crop of fieldstones. Then I got the pressure washer out and washed my tractors off. Two M's, a 706D, AND A 1586. Nothing like a yard full of shiney red tractors. .u
