FERGUSON TRACTORS
JAMIE BAXTER
06-03-2000 13:12:31
I WAS GIVEN A FERGUSON TRACTOR. HOW CAN I FIND OUT WHAT MODEL AND YEAR THIS TRACTOR IS? THE ONLY IDENTIFYING MARK IS A PLATE ON THE DASH WITH SEVERAL PATENT NUMBERS. ANY HELP WOULD BE APPRECIATED. IT WOULD PROBABLY BE EASIEST TO EMAIL ME. THANKS. JAMIE
Tom-Pa
06-03-2000 21:34:37
 Re: FERGUSON TRACTORS in reply to JAMIE BAXTER, 06-03-2000 13:12:31
The serial number at the top of the patent no. plate should start with a TO or TE (tractor Overseas or tractor England) and the next two numbers should be a 20 or 30. they indicate the model. This is for the straight Fergesons.
the rest of the number is the serial no.
Hope this helps somewhat.
Tom
R.de Bruin
06-04-2000 08:42:48
 Re: Re: FERGUSON TRACTORS in reply to Tom-Pa, 06-03-2000 21:34:37
try logging to FOFH.U-NET.COM and check with te serial number what the year of manufacture was.
jamie baxter
06-04-2000 06:47:09
thanks for the help. once i establish the year and make where can i find manuals for theses tractors? how is the availibilty of parts? thnaks for your help.
philip
04-11-2005 07:33:08
 Re: Re: Re: FERGUSON TRACTORS in reply to jamie baxter, 06-04-2000 06:47:09
Has the fergie got a small circle to put your foot on the skid brakes? if it is a ridge oval shape on the skid brakes she is 1948 or younger. if the skid brake has a small circle she is 1946 or 1947. Go to the offside of the tractor. then go to the back end. there is a number on the offside almost at the same place as the hydralic selector is on the nearside. the first number will give you the year she was made. ie if it is '9' shes 1949. if it is '3' shes 1953. fergies were made from 1946 to 1955. hope this helps ya.
philip
04-11-2005 07:31:20
Has the fergie got a small circle to put your foot on the skid brakes? if it is a ridge oval shape on the skid brakes she is 1948 or younger. if the skid brake has a small circle she is 1946 or 1947. Go to the offside of the tractor. then go to the back end. there is a number on the backend almost at the same place as the hydralic selector is on the nearside. the first number will give you the year she was made. ie if it is '9' shes 1949. if it is '3' shes 1953. fergies were made from 1946 to 1955. hope this helps ya.
