Splitting A Tractor
Rog
06-05-2000 23:13:48
I have to split my tractor in order to do some repair work. I am a rookie at this and would greatly appreciate any tips or hints to make the job easier. For instance, should I block the back end of the tractor solid and try then to move the front half away or visa versa?? Or does it matter.
I guess it will be a good learning experience. . .
Probably I will learn that I never will want to do it again!! Thanks for any advice.
MarkB
06-07-2000 17:18:14
 Re: Splitting A Tractor in reply to Rog, 06-05-2000 23:13:48
You don't say the make and model of the tractor. It makes a difference. If you possibly can, get the FACTORY service manual for your tractor; it will certainly show exactly what to do.
The earlier posts cover what to do pretty well. I recently split my 4 cyl Ford 4000 row crop. I followed the manual and didn't have any problems. You certainly want to do it on concrete, if at all possible. Here's the steps for my 4000:
1. Drain out the transmission, axle, and hydraulic reservoirs.
2. Shore up the front end of the tractor with some sort of cribbing so it won't fall over.
3. Put a block under the BACK end of the engine oil pan.
4. Unbolt the steering pedestal from the transmission housing. Hook an engine hoist or chain falls to the steering wheel and jack up the pedestal until its free of the transmission.
5. Put a hydraulic floor jack (with wheels) under the transmission. (You'll probably have to add some blocks to get it high enough.)
6. Disconnect anything that connected between the two halves. Electrical wires, hydraulic pump manifold, etc.
7. Take out the bolts that hold the front half to the back half, making certain that both halves are fully supported.
8. Roll the back end straight back, and your done.
9. On reassembly, the tricky part is getting the transmission shaft back into the clutch. It has to be aligned just right or it won't go.
Chris Graves
06-06-2000 07:21:18
My 2N is sitting in a field split in half right now . I have to put a new ring gear on the flywheel .
Splitting is no big deal . It took my Dad and me about 1-1/2 hr. to do the job .
I parked the tractor on a level spot in an old road bed . Put a sheet of plywood underneath to roll the jack on and went to work . First , disconect all wires and fuel line for the hood and take off the hood . Next , disconnect the oil gage , radius rods ,steering linkage and muffler.
Then , block the rear wheels . Put a jack and jackstand under the transmission to support it in place . I then put my rolling floor jack under the rear of the engine . After removing the bolts from the engine/transmission connection , you can carefully roll the engine away fron the tranny .
Both of us manned a front tire and carefully rolled forward . The whole setup is pretty stable and goes back together fairly easily .( I did the whole thing by myself when I put in a new clutch a few years ago ) . It is much easier with two people .
Just make sure that you are on level ground and block the back wheels and use jack stands . Watch where you stand at all times just in case the worst happens ! Nobody wants a tractor to land on them !
Good Luck and be careful !
Chris
G. L. Perry
06-06-2000 02:41:24
Me too! I have an MM that needs a clutch and maybe
a rear seal. I'm gonna build two rolling supports
or dollys that I'll bolt to tractor halves and leave wheels on to roll apart. Both should balance
ok, I hope! I bought 2 extra long hard bolts to use in holes for bolting together as a guide pin. Be careful that you brace front so it doesn't tip
at axle pivot and fall over. I'm gonna watch this
site for answers to your request. "G"
Dave Neubert
06-06-2000 14:42:39
 Re: Re: Splitting A Tractor in reply to G. L. Perry, 06-06-2000 02:41:24
I use a floor jack under the front half and put blocks on both sides of the front axle to keep it from pivoiting. If you have a tractor with a narrow front end I use a engine hoist [cherry picker] and attach a sling higher up to make it stable. block the rear tires or lock brakes and move the front away. the long bolts or studs work good to line it up when goging back together.If you have to take clutch apart be sure it is lined up.Do not use long bolts to force it together.If lined up it should go together within a half inch. then if it is not perfictly lined up put a little tension on it and turn motor over by hand ann the pilot bearing should line up and go together the rest of the way. Take your time and dont force it it is not that hard.Concrete is the best to do it on. If not avilable find a level area and put plywood or a metal plate down to work on.
