12 V Conversion
a question on the starter 'ground' ????
Alberta Mike
07-07-2000 15:01:40
Read the 12 Volt conversion article on the YT homepage and I've got another question about it. All of the old stuff was + ground. So when you convert to a 12V system (like the article) using a modern 12V negative ground alternator, the whole system is then negative ground right? If that's the case, the original 6V starter must be a positive ground starter. Would this not mess up the starter, that is to operate it in a negative ground system?
Roger McKenzie
06-12-2005 13:48:35
 Re: 12 V Conversion - a question on the starter 'g in reply to Alberta Mike, 07-07-2000 15:01:40
I have a 1969 or 1970 oliver. Gas powered I would like to know is the battery positive or negitive ground going to the voltage regulator it is a 12 volt system.
ROBERT
07-08-2000 19:47:16
 Re: 12 V Conversion - a question on the starter 'ground' ???? in reply to Alberta Mike, 07-07-2000 15:01:40
DOSE THE COIL WIRES NEED TO BE CHANGE?I BELEVE THEY DO. ROBERT
twopop
07-07-2000 18:13:05
the starter will not care whether the ground is - or + and it will turn the proper direction
