Tractor Talk Discussion Forum
OT? Road Ranger Air Shifter Leak
uncle
06-04-2007 20:24:08
I had an air leak on my 13sp RR. I took it apart and cleaned the surface and it still leaks. Is there a special coating or something to put on it?
Brian
Bob
06-04-2007 22:00:09
 Re: OT? Road Ranger Air Shifter Leak in reply to uncle, 06-04-2007 20:24:08
Is the leak at the gearshift knob shifter valve?
If so, replacement units are surprisingly affordable.
I've put new "O" rings in several over the years, and it was always a short-lived fix.
Now, I just replace the shift knob unit.
Cory A.
06-04-2007 20:58:14
where exactly is the leak at? on the slave or the splitter valve? or is it in the rear box?
Rex in Australia
06-05-2007 02:05:06
 Re: OT? Road Ranger Air Shifter Leak in reply to Cory A., 06-04-2007 20:58:14
Replace the seals with the proper Fuller items, with a SMALL amount of a silicon type grease for lubrication. You should have no problems after that.Make sure there are no cracks or nicks in the surfaces.
God Bless,
Rex
