Can you get PB Blaster penetrating oil in Canada ???
Alberta Mike
08-11-2000 05:46:29
Been reading the tool talk forum and PB Blaster penetrating oil is often mentioned. Does anyone know if you can get it in Canada, and if so who sells it? Sounds like a guy needs some if it's as good as they say. Thanks.
Larry (ks)
08-13-2000 13:21:39
 Re: Can you get PB Blaster penetrating oil in Canada ??? in reply to Alberta Mike, 08-11-2000 05:46:29
I can't vouch for the penetrating qualities of pb blaster, but I can give you one use for it---Killing wood bees. I had some that seemed to be immune to all kinds of insect sprays---read one time from a post on here how pb blaster kills wood bees....I sprayed it into the holes they had made, and it killed the ones in there, and I haven't seen a wood bee around there since!!! I couldn't believe it, I had been spraying them and nothing seemed to work, but the pb blaster did it, and didn't seem to stain the wood or anything....I have no idea why it works so good on them! I did (and do) have an M farmall with a stuck piston, the pb blaster didn't "undo" 20 years of rust though!!
Marq
08-22-2004 19:48:40
 Re: Re: Can you get PB Blaster penetrating oil in in reply to Larry (ks), 08-13-2000 13:21:39
WD 40 is also instant death for wasp... I don't know what it is that they don't like about it... but it hits them hard and instantly. They don't even have a chance to get mad before they drop dead...
dan carter
08-12-2000 20:20:20
AB Mike, I get PB Blaster right at UAP NAPA and I live north of Edmonton 2 hrs. Its about 6$ a can.
Howard
11-23-2000 16:46:46
 Re: Re: Can you get PB Blaster penetrating oil in Canada ??? in reply to dan carter, 08-12-2000 20:20:20
Hello Dan:
I work at a Ford Motor Company Dealership in Winnipeg, Manitoba (Canada) and I am trying to locate this PB Plaster for a tech in the shop. Could you supply me with a store address and a phone number where I can buy this stuff.
Thanks in advance.
Nathan(GA)
08-11-2000 18:52:53
Mike, I don't know what kind of regulation there is as far as shipping across the border. If not any, check with Steve at US Alloys over on the tool talk board. He said they sell it and listed an 800 number. You can buy it in all sorts of stores here.
clooney
08-11-2000 17:29:59
Alberta Mike, PB blaster isn't magic but it is the best I have found yet. I buy it by the case. Check on line maybe they can send it to you.
Tom M
08-11-2000 16:10:11
I am also interested in this product - sounds like the greatest invention since sliced bread. A friend of mine, who is a Manufacturers Agent, is checking it out. Will keep you posted.
Tom
Karl in MD
08-11-2000 22:17:34
 Re: Re: Can you get PB Blaster penetrating oil in Canada ??? in reply to Tom M, 08-11-2000 16:10:11
PB is the only penetrant I'll use on the farm. I work for a Pepsi Bottler and it's the only thing the maintenence super will let in the plant. One of my hunting buddies works for CSX and it's all they use in their shops. The only thing that's close is Kroil, but it's hard to get. WD-40 isn't even worth fooling with, except for arthritis. It won't even work as starting fluid anymore.
Some big shots that tried both say Kroil is better too!
08-12-2000 09:18:39
 Re: Re: Re: Can you get PB Blaster penetrating oil in Canada ??? in reply to Karl in MD, 08-11-2000 22:17:34
Not hard to get either
http://www.kanolabs.com/kanopnlu.htm
