Sears ST/16 Garden Tractor
Jeff Gilbert
09-06-2000 16:01:33
I have a Sears ST/16 Garden Tractor. Tractor Model #917 25741
Serial # 2208
Engine Model # 143.640012
Engine Part # 640012
I blow the crankcase gasket and have disassemblied the Cover Assembly to replace the oil gasket. I am looking for the technique to align the timing and counter balance gears for reassembly. Thanks!
Regards
Jeff Gilbert
czimpel
12-30-2004 14:28:35
 Re: Sears ST/16 Garden Tractor in reply to Jeff Gilbert, 09-06-2000 16:01:33
There should be two pipe plugs in the side of the crank case cover. They usuall are a square head. Take them out, and with the crank and cam aligned you should see two slots in the pipe plug holes. It may help to look at the slot in the balance shafts before you reinstall the cover, so you know what you"re looking for. Hope this helps.
JIMMY
09-08-2000 21:37:42
The "143" says that it is a Techumseh Engine, if that helps any.
