Tractor Talk Discussion Forum
two questions/ overrun pto att. ford rims
BLW
06-05-2007 06:57:33
1st I have an overrun attach on a tractor I bought that was used for a brush cutter-- it keeps falling off the pto-- and I can't see any thing there to hold it on et. pin or clamp ?? any ideas-- also we have a 2N- 8N-- and a fergie 20 I need to mount a tire for a spare (rear) it looks like the outside rim is the same size and bolt pattern, is this true and will the rim and tire interchange on these tractors / I know the wheel is different but I am talking about the outer rim thanks for any info
old
06-05-2007 07:38:57
 Re: two questions/ overrun pto att. ford rims in reply to BLW, 06-05-2007 06:57:33
ORC is held on by a roll pin, 2X5/16 if I remember right. You have to remove the grease zirk and the plug to see how to install the pin. The outer rims will fit from the 2N and the 8N not sure on the other tractor. All rims from the 9N up to the 3000 series will fit on all of the model or most of them unless they have the power adjust rims on them
BLW
06-06-2007 06:41:28
 Re: two questions/ overrun pto att. ford rims in reply to old, 06-05-2007 07:38:57
hey OLD thanks a lot that's what I suspected but wanted another opinion-- sounds confusing on the orc but I will have to put it in the vise and lood it over good-- too bad there isn't a book that comes with them to explain the operation. but I guess I can figure it out thanks again-- PS do you know anyone that has these ford rims used reas. and close to the northeast NY
old
06-06-2007 08:18:48
 Re: two questions/ overrun pto att. ford rims in reply to BLW, 06-06-2007 06:41:28
I have 2 or 3 rims here but I'm a long ways from you. As of right now I know I have 3 one hand 1 is on a 2N
