Determining cubic yard for bucket
PJ
12-26-2000 16:56:24
I'm in the process of building storage bins for mulch and rock. I may at times be selling some to others and want to know how to determine cubic yard capacity of my bucket. My bucket measures 69" X 24" and 19" deep at its deepest point. Thanks everyone and have a great new year!
LB
07-12-2002 12:57:40
 Re: Determining cubic yard for bucket in reply to PJ, 12-26-2000 16:56:24
Can someone give me the formula to convert square foot to cubic yard. Thanks;LB
JB
07-24-2002 17:54:04
 Re: Re: Determining cubic yard for bucket in reply to LB, 07-12-2002 12:57:40
You will need the height (or depth) for this conversion since a square foot is based on the length times width and a cubic yard uses length times the width times the heigth. You can convert the square foot to cubic yard by converting the square footage to inches and using the formula by multiplying the length x width x height to get cubic inches (CI). Then your conversion formula would be: Cubic yards = CI/1768/27 or length x width x height inches divided by 1768 then divided by 27.
Jay Amaya
07-09-2002 08:51:02
How would I know how much concrete I need for a 20 X 6 X 3 inch deep.
RWK in WI
12-28-2000 08:25:01
Good advice below but maybe an easier way. Load your bucket with a normal load and they dump it in a clean area of concrete or on a couple of pieces of plywood. then shovel it into a know measuremnt containers - 55 gal drum, 30 gallon trash buckets. or make a bin of wood that holds exactly a cubic yard / 27 cubic feet. A 3 X 9 form of 1X12's comes to mind. This may be an alternative for you
Dick Kraus
ltf in nc
12-27-2000 06:59:33
Not to cast a shadow on your project but you need to determine the impact that your state has on weighing items for resale. In many states it is illegal to sell without scales. You can charge a fee to load but you cannot sell by weight or cubic measure without state approved measuring equipment. Around here, for small operators for example, fill dirt is loaded at $5 per bucket and the truck driver/owner sells the load at a "delivery" price. The amount of dirt (in tons or cubic yards) is never entered into the price reflected on the bill. Knowing the size of your bucket will assist in determining the "loading" fee. Good luck.
Bobduck
12-26-2000 22:19:31
Is the cross section of your bucket (shape of the side)not a rectangle but rather similar to a section of a circle with the bottom flat where it contacts the blade?
If so do the following:
Determine where the shape of the side of the bucket changes from a curve to straight. Draw a line from that point to the other end of the curve of the bucket. Measure the length of this line. Then find the midpoint of this line and measure perpendicular from that point to the back of the curve of the bucket.
Then measure from the point you earlier determined where the side of the bucket changes from a curve to straight to the front of the bucket.
Send me these three measurements and I'll calculate it for you.
If it's not clear what measurements I want contact me by email and I'll discuss it with you in more detail.
shawnp
02-27-2005 20:55:49
 Re: Re: Determining cubic yard for bucket in reply to Bobduck, 12-26-2000 22:19:31
how many cubic yards of sand will you need for six inces of beding for six hundred feet of waters lines if the width is six inches
JILL
06-29-2002 13:50:43
HOW MANY BAGS (80 POUNDS) CEMENT WOULD I NEED TO LAY A CONCRETE STEP WHICH REQUIRES 1 CUBIC YARD OF CONCRETE?
T_Bone
12-26-2000 21:29:16
Hi PJ, LXHXW=ci/1728/27
L=length in inches
H=hieght in inches
W=width in inches ci=cubic inches
1768= ci in a cubic yard.
27= cubic feet in a cubic yard. Your is = .67c/yd cubic yard= 3'X 3'X 3'
T_Bone
walt
12-26-2000 19:30:00
I get close to 2/3 of cubic yard.
Length x width x depth /27. Use increments in feet. ie 24"=2', 19"=1.5'approx. etc
Al
12-26-2000 17:47:55
PJ,if your bucket is a full cube it would be 1 1/3 yrds.If your bucket is wedge shaped like most are,and the never fill 100%,you could bet on having an honest 3/4 yrds in yours.I'm far from a mathmatition,so listen to other opinions,but thats mine.Hope it helps
Al
Al
12-27-2000 05:40:01
 Re: Re: Determining cubic yard for bucket in reply to Al, 12-26-2000 17:47:55
T-bone has the correct numbers.I used the squared # to convert from inches to yards,silly me..674 cubic yards is my final answer,based on a cube.Adifferent shape(radius or angled bottom)will reduce that.
Al
Al
12-26-2000 17:46:54
Al
jimmyzz
12-27-2000 00:26:24
 Re: Re: Determining cubic yard for bucket in reply to Al, 12-26-2000 17:46:54
You can measure with water. there are 231 cu in.. in one gl of water. 46,656 cu. in. in cu. yd. so if you fill bucket with 5 gl. pail just figure out how many gls or cu. in. of water. put the cu in. determined over 46,656 , and lower to lowest deniominator. that will be cu. yds. level bucket. have fun.
chief613
12-27-2000 15:42:11
 Re: Re: Re: Determining cubic yard for bucket in reply to jimmyzz, 12-27-2000 00:26:24
another route for this method
fill a few five gallon buckets with ur hose to see ur gallons per minute. then fill ur bucket and then mutiple ur g/m by the time it took to fill, then the rest of the math above
