Case Crossmotor
Rick
12-28-2000 19:54:19
Need a carburator for a friends Case Crossmotor 12-36, Thanks for any help.
Spencer Timm
12-26-2006 12:26:26
 Re: Case Crossmotor in reply to Rick , 12-28-2000 19:54:19
Im not totally sure if your intake is the same, but our 12-20 has a farmall M carb on it. It went right on to the brass intake flanges. It runs really nice with that on there and its so much easier to adjust and work with. In the last 20 years only one old timer has actually caught it.
Allen
12-29-2000 18:08:10
Try one from an L or LA, it should work to get it running, or until you find the right one. You'll probably have to run it on gasoline though. We did that with a DC carb on our 12-20, (the diverters are stuck, so we can't run Kero anymore) it starts easier, runs cooler, and doesn't use near as much gas as it used to.
