Ford 555B Backhoe 12-17-87 Axle leak at boots
Jack Plank
03-19-2001 19:12:32
This Ford 555B leaks the rear axle fluid out of both of the rubber boots where the brake actuating rods enter the axle.
Is this a relatively easy fix and is there something else I need to be checking?
I've ordered new manuals for this machine but it will be at least a week before they get here. I'm just trying to pick up some advice from you experienced wrench burners! :) Any help will be appreciated folks. Thanks.
Jack Plank
Tom Lewter
01-12-2006 22:18:31
 Re: Ford 555B Backhoe 12-17-87 Axle leak at b in reply to Jack Plank, 03-19-2001 19:12:32
I have a ford 5000. The left side leaks where the brake rod goes into the axel. Is this the problem you had and how hard was it to fix:? Mine pours fluid when the brake is locked and has started doing it in neutral now.
Dale Powell
03-19-2001 20:40:49
 Re: Ford 555B Backhoe 12-17-87 Axle leak at boots in reply to Jack Plank, 03-19-2001 19:12:32
I just did this job on a 545 at work. The boots just pry out from the outside.
Jack Plank
03-20-2001 06:03:13
 Re: Re: Ford 555B Backhoe 12-17-87 Axle leak at boots in reply to Dale Powell, 03-19-2001 20:40:49
Dale,
Thank you for your quick response. I was sure hoping this was the case but I was positive. You've certainly made my day more enjoyable! :)
Jack
