Freeing up disc space on the hard drive
tommyw
05-10-2001 20:12:37
can someone tell me how th free up some space on my hard drive and run a scan disc, ihave tried but with no luck, any advice is very much needed , thanks in advance
grace parker
06-04-2002 17:39:27
 Re: freeing up disc space on the hard drive in reply to tommyw, 05-10-2001 20:12:37
i have the millinnuim windows. can you help . tell me how to free up space on my hard drive thanks
pam huyer
08-21-2003 22:10:58
 Re: Re: freeing up disc space on the hard drive in reply to grace parker, 06-04-2002 17:39:27
how do i do this task
walt
05-11-2001 05:05:59
Here is a link for Win98, if your running Win95, look to the left under Tips & Tricks for Win95.
F14
05-11-2001 03:27:13
Tommy, what software are you using? Win95 or Win98? What browser and version? (Netscape or Internet Explorer) If you're using IE, go to the Tools menu, Internet Options, go the the Temporary Files section and hit the delete files button.
If you are using Win98, go to "My Computer", RIGHT-click on the C:\ drive, and select the properties tab. On the lower part of that menu, next to the pie-graph of the drive, there is a button marked disk cleanup.
Also, hit the Start button, select Find, and look for any files ending with .chk (If you enter *.chk it will find them all) Delete them.
Finally, find the Temp directory in the Windows folder, and delete all files ending in .tmp
You'll be surprised how much spare that clears up if you haven't done it in a while.
Murphy
05-11-2001 08:55:17
 Re: Re: freeing up disc space on the hard drive in reply to F14, 05-11-2001 03:27:13
F14, what are .chk files?
F14
05-11-2001 09:20:53
 Re: Re: Re: freeing up disc space on the hard drive in reply to Murphy, 05-11-2001 08:55:17
When (not if) your Windoze computer crashes, or if it's shut down improperly, it will run Scandisk. When running Scandisk, it will find fragments of files from the crash, and other trash files. Unless you tell it not to, Scandisk will save those file fragments. The idea is you can reconstruct lost files from these fragments. In fact, it rarely, if ever, works. It saves these files as file000001.chk, file000002.chk etc, and usually stores them in the root of the c:\ drive. They are worthless, and can be VERY large, sucking up a lot of disk space.
John
05-10-2001 20:57:57
Use something like a Zip Drive to store files that you need but do not use often. Then delete those files from your hard drive.
pudding
05-13-2001 19:52:59
 Re: Re: freeing up disc space on the hard drive in reply to John, 05-10-2001 20:57:57
while ya touring round internet explorer
go tools/internet options/ open it and on the bit that opens there will be a frame with Temporary internet files title in it, and two buttons, one to delete files..... hit that if you want
and another for settings....click that....in there you will find a slide bar for allocation of disc space for temporary internet files...screw that back..... you don't need a lot of space for them..... .especially if the sites you visit change all the time..... ...like this one
you can comfortably get away with 10MB or so
your c: drive needs 500mb spare to run most applications
windows standby function (in the desktop propertys menu) will not work under 250mb..... ..cause it recognises there is not enough temporary space to hold programmes in stand by..... ..therefore the computer will crash
there is a handy little programme available on the net for free called TWEAK UI..... ..definilty worth looking at
but if you are looking at freeing up space by optimising applications.....installing it will only use the space you found..... lol
rember when running system tools like defrag,scandisk..... .make sure the standby funcions....(power save in the desktop propertys) is dissabled, turn all other programs of....and if you go control-alt-del once (twice will restart the computer)....all programs except explorer should be dissabled to do an effective scandisk and defragment
best of luck
pudding
