New old stock parts
John Smith
05-06-1998 22:42:11
i sell new old stock parts for gas engines :Briggs,Clinton,Lauson,Tecumseh,Onan,Wisconsin,Kohler,also sell used parts and motors hundred in stock and also am selling my two wheel tractors and mowers old ones wards,bolens,hoetrac,cunnigham,zipper,jari,etc.....
john smith pobox163 Flanagan illinois 61740
Rick Krahmer
07-17-1999 18:50:27
 Re: new old stock parts in reply to John Smith, 05-06-1998 22:42:11
: i sell new old stock parts for gas engines :Briggs,Clinton,Lauson,Tecumseh,Onan,Wisconsin,Kohler,also sell used parts and motors hundred in stock and also am selling my two wheel tractors and mowers old ones wards,bolens,hoetrac,cunnigham,zipper,jari,etc.....
: john smith pobox163 Flanagan illinois 61740
:John i have a HT-20i am looking for a muffler that came with the tractor, please let me know , thanks
gary
01-24-2004 22:19:37
 Re: Re: new old stock parts in reply to Rick Krahmer, 07-17-1999 18:50:27
Hi I am looking for a wards riding mower that was made in the early 60's the engine was in the middle between your legs and there was a pedel on the right side front to stop it and the blade handle was also on the right side by the engine. The gear shift was under the seat, the deck did not adjust and it had handle bars.The frame and deck were all one.I have a picture of one but that is all would like to know the model# or anything about it that would help me find one.Thank you.
Martin Mathis
04-21-1999 11:32:54
::: I am searching for parts to a Tecumseh 5hp, 2-cycle engine. I need a carburetor and reed. Reed - Tecumseh part #470125..... ..Carburetor - Tecumseh part #631007 Anything working or rebuildable is OK. Call Martin at - (703)413-3569
lance lagace
07-20-2002 05:46:01
 Re: Re: new old stock parts in reply to Martin Mathis, 04-21-1999 11:32:54
I need a carburetor for a 3.5 horse tecumseh engine.I would like a brand new one if possible.
Aaron G.
05-07-1998 06:09:59
John I am fixing an oliver super 55. I am not sure what is wrong with the engine yet
but I am looking for parts like crank shaft rings gaskets... do you have parts like this.
Are they easy to find or not? The engine was making a loud knocking sound. I found pieces
of metal in the oil pan so it had to come from the front of the motor. I could not see
anything broken from underneath. I have to take the water pump and the cover on the front
of the engine to see if it is a gear that the teath are broken off of or what.
john smith
05-07-1998 21:59:11
 Re: Re: new old stock parts in reply to Aaron G., 05-07-1998 06:09:59
i dont carry any bigtractor engine parts exept for some used carbs that ive boughten recently
john smith
: : i sell new old stock parts for gas engines :Briggs,Clinton,Lauson,Tecumseh,Onan,Wisconsin,Kohler,also sell used parts and motors hundred in stock and also am selling my two wheel tractors and mowers old ones wards,bolens,hoetrac,cunnigham,zipper,jari,etc.....
: : john smith pobox163 Flanagan illinois 61740
: John I am fixing an oliver super 55. I am not sure what is wrong with the engine yet
: but I am looking for parts like crank shaft rings gaskets... do you have parts like this.
: Are they easy to find or not? The engine was making a loud knocking sound. I found pieces
: of metal in the oil pan so it had to come from the front of the motor. I could not see
: anything broken from underneath. I have to take the water pump and the cover on the front
: of the engine to see if it is a gear that the teath are broken off of or what.
Aaron G.
05-08-1998 05:10:55
 Re: Re: Re: new old stock parts in reply to john smith, 05-07-1998 21:59:11
: i dont carry any bigtractor engine parts exept for some used carbs that ive boughten recently
: john smith
: : : i sell new old stock parts for gas engines :Briggs,Clinton,Lauson,Tecumseh,Onan,Wisconsin,Kohler,also sell used parts and motors hundred in stock and also am selling my two wheel tractors and mowers old ones wards,bolens,hoetrac,cunnigham,zipper,jari,etc.....
: : : john smith pobox163 Flanagan illinois 61740
: : John I am fixing an oliver super 55. I am not sure what is wrong with the engine yet
: : but I am looking for parts like crank shaft rings gaskets... do you have parts like this.
: : Are they easy to find or not? The engine was making a loud knocking sound. I found pieces
: : of metal in the oil pan so it had to come from the front of the motor. I could not see
: : anything broken from underneath. I have to take the water pump and the cover on the front
: : of the engine to see if it is a gear that the teath are broken off of or what.
Thanks anyway
