Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: Re: Re: Re: Re: International TD 4 crawler dozer
Posted by clark on May 19, 2002 at 16:39:53 from (64.12.104.44):
In Reply to: Re: Re: Re: Re: International TD 4 crawler dozer posted by Bob Buterbaugh on May 19, 2002 at 15:54:05:
if it has a injection pump and injectors its a diesel, the gas part of the engine is for starting ONLY..its a unique feature that IH only used, it starts up on gas after warmeing up for a few minutes you push the lever and it switches it over to diesel and kills the gas ignition and closes off the intake to the gas side.. before you purchase the crawler i would advise that you hear it run on DIESEL>. all the start on gas engines were prone to cracking heads.. the reason they cracked was whoever run the machines all day would shut them right down, this is a NO NO,, they should set and idle for atleast 20 min to cool the head down then its safe to shut them off..if the eng dont run properly then you can assume that the engine will need extensave (expensive) work. i am currentley rebuilding a TD-6 eng that has a bad head..
Post A Followup
: Re: Re: Re: Re: Re: Re: International TD 4 crawler dozer
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
