Re: 656 carburetor
Posted by karl f on March 13, 2009 at 19:53:12 from (172.162.205.81):
In Reply to: 656 carburetor posted by Bob And on March 13, 2009 at 19:00:24:
Should still be available new from caseih. helps if you bring in carb, carb tag, old part, or if you can identify whether you have IH, marvel, or zenith carb.
if you still have problems, check your wiring. the wiring harnesses on our 656 corroded up really bad under the dash in the circuit for coil, warning lights/gauges and carburetor solenoid, and was giving intermittent problems.
in the 28 years i've known the tractor, we've gone in spurts with that solenoid, a few in a row then for about 10 years without. earlier "failures" may have been due to the wiring issue.
issues with how it runs can be fuel supply (tank, lines, vent) air filter, worn throttle shaft, internal part damage of carburetor, heat riser failure, worn distributor bushings, and/or distributor cam lobes. also worn out engine...
good luck
karl f
