Farmall Tractors Discussion Board
Re: Polarizing a generator for 12v lo-boy
Posted by JW on January 27, 1999 at 12:00:27:
In Reply to: Polarizing a generator for 12v lo-boy posted by Scott on January 27, 1999 at 08:15:01:
After new regulator has been installed and grounded, connect cables to the battery again, before starting engine you,
must polarize the generator to match battery.
Momentarily touch one end of a piece of wire (your supply) to regulator terminal marked "arm" or "gen" and the other end of
that piece of wire to the terminal marked "bat" then remove. A spark will occur when wire is removed. This is natural.
HOWEVER, DO NOT TOUCH "FLD" TERMINAL. IF YOU DO, THE REGULATOR WILL BE INSTANTLY RUINED.
Hope this helps.
Post a Followup
: Re: Re: Polarizing a generator for 12v lo-boy
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
