Re: Increase Hp on a Farmall M
Posted by Medfarm on January 29, 2001 at 21:58:29 from (216.224.160.202):
In Reply to: Increase Hp on a Farmall M posted by Don on January 29, 2001 at 19:37:26:
Don
Without doing engine modifications, your tractor can run better with new sparkplugs, ignition components and the proper ignition timing. The carb should be adjusted for proper atomization of fuel at low and high rpm's. The governor can be tweaked up to 1725 rpm's. New tires, correct air pressure and the proper placement of weights is absolutely esential to to a competitive pull irregardous of the weight class and horsepower rating of the tractor. The most important consideration of tractor pulling is to have FUN and meet fellow competitors and friends.
Post A Followup
: Re: Re: Increase Hp on a Farmall M
