Re: 1941 Farmall H buy or not
Posted by Dick Davis on January 30, 2001 at 06:12:20 from (205.188.199.49):
In Reply to: 1941 Farmall H buy or not posted by Junkman on January 29, 2001 at 20:22:11:
Junkman,
There is no inherient weakness with the H model. Things to look for in desending order of importance [in my opinion]:
First thing to check is engine oil - for quanity and quality - antifreeze? water? foamy? also check the transmission fluid for foreign stuff
(1) Does it start easily and run smoothly at all throttle settings.
(2) Does the transmission shift smoothly and does the tractor move quietly in each gear - (especially does it kick out of gear in 5th)
(3) Does the steering wobble excessively at road speeds
(4) do the belt pulley and PTO engage and run quietly
(5) Are there any significant leaks anywhere
(6) how are the tires
(7) how is the tin
If the machine passes all these with flying colors it's a keeper. Hope this helps. Dick Davis
By the way if you buy the Farmall, and especially if you unload the JD, you will be able to change your name!
Post A Followup
: Re: Re: 1941 Farmall H buy or not
