sediment bowl/strainer valve leaking on A
Posted by RobertN on January 31, 2001 at 16:45:30 from (132.233.247.4):
I put a fresh carb on my "A". My next task is the fuel strainer/sediment bowl/valve on the bottom of the tank. It leaks whether the gas is turned on OR off.
It appears to be coming from the seal where the "lever" you turn sticks out. I had partially disassmebled and cleaned it, but it still leaks.
Are there seals I can replace, or do I need to find a replacement? What about replacement screens and gaskets for the sediment bowl?
Thanks!
Post A Followup
: Re: sediment bowl/strainer valve leaking on A
