Re: Re: CAN YOU HELP
Posted by Wardner on February 01, 2001 at 09:17:15 from (63.23.215.148):
In Reply to: Re: CAN YOU HELP posted by Phil Auten (TX) on February 01, 2001 at 07:02:04:
Your 340 is a '59 or later. If you are using Hy-tran or equivalent(that is what's specified), I would doubt that you have water or ice. Moisture will be suspended in that type of lubricant. You probably have a relief valve that's stuck open. The 340 is the predecessor to the 504 which has two relief valves. Don't know how many you have.
Post A Followup
: Re: Re: Re: CAN YOU HELP
