Re: Removing Bolts
Posted by Andy Martin on February 02, 2001 at 20:44:17 from (38.31.74.14):
In Reply to: Removing Bolts posted by 1PWRFULH on February 02, 2001 at 19:38:14:
I agree with George on easy-outs.
Take the side rail off so you can get to the bolt then weld a nut onto it. The welding heat does wonders to break the rust. You (or any decent welder) can weld a nut onto a bolt that is flush or a little below the surface it is stuck in. Since it is in cast material you will not have to worry about weld metal sticking to the housing.
Post A Followup
: Re: Re: Removing Bolts
