Re: Re: Re: Removing Bolts
Posted by George Willer on February 03, 2001 at 14:11:10 from (205.133.30.53):
In Reply to: Re: Re: Removing Bolts posted by bob on February 03, 2001 at 12:44:27:
Bob,
Maybe I live too sheltered a life. Have you discovered a new kind of easy-out that can grip without expanding the remaining part of the bolt? Expanding is exactly what you DON'T want to do. In most cases, the bolt is broken because it is stuck TIGHT in the hole. Why on earth would you use something that will expand the bolt and make it even tighter? Throw those !@#$% easy-outs in the junk where they belong! I can't think of a way that is not better for removing bolts.
George Willer
Post A Followup
: Re: Re: Re: Re: Removing Bolts
