Re: farmall A pnumatic lift
Posted by gene b on February 04, 2001 at 19:45:25 from (63.15.137.201):
In Reply to: farmall A pnumatic lift posted by jeff kavanaugh on February 04, 2001 at 08:05:34:
make mine out of some thick leather can send on if you need one I USE A ROUND PIECE OF WOOD TO HONE THE CYCL FIRST put some 9 in sand discs on it and use a drill soak the leather in oil use a large hose clamp they work fine new ones were avail at 42 last time i checked
Post A Followup
: Re: Re: farmall A pnumatic lift
