Re: A tractor won't slow down
Posted by Richard on February 05, 2001 at 05:56:02 from (209.92.137.143):
In Reply to: A tractor won't slow down posted by MAX on February 05, 2001 at 05:22:45:
You didn't say if you have this problem in the summer months, but my Super H sometimes has this problem because the carburetor is getting frosted up on the outside. Also, make sure there are no air leaks at the float bowl, where the carb bolts to the manifold, and where the manifold bolts to the head. A lean mixture can cause a high idle situation. Good luck. Richard.
Post A Followup
: Re: Re: A tractor won't slow down
