Part of B Casting Broke
Posted by Red Raider on February 05, 2001 at 07:45:20 from (192.105.235.146):
This weekend I tore into the '40 B in ernest. Wrastled the engine off and now I'm left with just the torque tube, axles, and final drives. The PO had repaired the casting where the brake and clutch pedal shaft mounts, and came off. I have the two pieces to the casting. Has anyone fixed this problem? I was thinking of installing an ell that could be fastened to the casting by tapping a hole. The ell would then support the remaining pieces to enclose the shaft. Would this work or is there a better way. Seems to be overkill to find a salvaged torque tube at the bone yards.
third party image
Post A Followup
: Re: Part of B Casting Broke
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
