Re: M Farmall on LP using way too much fuel
Posted by T_Bone on February 05, 2001 at 10:47:43 from (207.254.52.202):
In Reply to: M Farmall on LP using way too much fuel posted by Matt Harrington on February 05, 2001 at 09:01:58:
Hi Matt, You need to buy a service manual as there's alot of adjustments and it will also explain how everything works. Remember propane is heavier than ambient air and will settle at the ground so I suggest until you get every thing running correct, keep your tractor stored outside well ventalated.
A regulator is a constant pressure device and takes a higher pressure input to a low pressure output at a constant gas volume. They can be liquid inlet, vapor outlet or vapor inlet, vapor outlet.
T_Bone
Post A Followup
: Re: Re: M Farmall on LP using way too much fuel
