Re: bending cast iron
Posted by Wardner on February 05, 2001 at 11:14:13 from (63.23.215.139):
In Reply to: bending cast iron posted by David Saville on February 04, 2001 at 20:51:33:
Some people have trouble distinguishing between a forgeing and a casting. All ferrous forgeings are steel and that is probably what you have. Take a grinder and generate some sparks on the metal. Do this with some known samples of cast iron and structural steel. You will see that the cast iron produces small red sparks and steel will produce larger yellow sparks.
Post A Followup
: Re: Re: bending cast iron
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
