Re: Farmall M (Fuel consumption)
Posted by Andy Martin on February 05, 2001 at 16:02:28 from (38.31.75.165):
In Reply to: Farmall M (Fuel consumption) posted by LeRoy on February 04, 2001 at 19:19:47:
You'll have to refuel at lunch plowing but should go all day with a 9-ft disc. If you are discing light enough to pull in 3rd you could go all day with a 10 ft disc too.
Check the Nebraska tests for hp-hr/gal, then assume 35 hp pulling it's guts out and 20 hp under light load. It is hard to get the ground conditions right to actually consume 35 hp with an M.
Fuel consumption will normally range from 1.5 gal per hr unloaded to 3.5 gal per hr fully loaded.
Post A Followup
: Re: Re: Farmall M (Fuel consumption)
