Re: After market air conditioning unit for 3088?
Posted by T_Bone on February 05, 2001 at 17:38:26 from (207.254.53.71):
In Reply to: After market air conditioning unit for 3088? posted by Terry Weivoda on February 05, 2001 at 03:44:29:
Hi Terry, You sure can get them. The ones made for tractors are going to be a bit more expensive than buying one for a pick-up or van. There basicly the same unit other than you might have to get the correct air vents for that tractor model. If your not concerened about looking "factory" then a add on pick-up kit will install fine.
Get a piston compressor and do not settle for anything less. York is the best compressor make. Never install a radial compressor. They even make precharged kits so you don't even have to charge the system when your done, so you just bolt eveything in and screw in the precharged lines ans cut a few holes. There is also a package unit that reseambles a RV, AC unit with out any vent work and installs on top of the cab, but these were a tad more expensive.
Most larger cities have a after market auto AC company that sells kits. I would try local first as the companys like people who are not in busniess as when a compressor fails, it's a bad installation and not the mfg's fault! If your buying a package unit this wouldn't apply.
T_Bone
Post A Followup
: Re: Re: After market air conditioning unit for 3088?
