Re: Re: Steering tight on farmall cub
Posted by Bus Driver on February 05, 2001 at 19:26:23 from (207.144.130.203):
In Reply to: Re: Steering tight on farmall cub posted by George Willer on February 05, 2001 at 14:33:13:
Sometimes the (essentially) vertical spindle housing will get bent or the vertical housing will crack just below the axle. This will cause very stiff steering. Clean the area just under the axle and look for a crack on one or both sides. To educate us, please post when you find the cause.
Post A Followup
: Re: Re: Re: Steering tight on farmall cub
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
