Re: Re: Super A oil seal question
Posted by BIG on February 05, 2001 at 19:43:12 from (63.26.230.166):
In Reply to: Re: Super A oil seal question posted by Duner Wi on February 05, 2001 at 17:46:06:
The National seal the bearing house gave me is #473380, its dimensions are id-1.000, od-1.575, thickness-.250. This is the same as you mention except the od. This national seal feels like the same od as the seal I removed from the tractor. Maybe it is right and the number I found on the internet that you crossed wasn't correct to begin with. Can you cross the 86956D number to anything like National, Victor or CR? Thanks for your help.
Post A Followup
: Re: Re: Re: Super A oil seal question
