Expert Opinion
Posted by Scott Green on February 05, 2001 at 19:58:17 from (209.130.130.109):
OK all you Farmall experts , Would you give me your opinion to the following situation: A neighbor of mine has a Farmall 560 tractor. The hydraulics won't work in cold weather. They will , but only after the tractor has run for quite some time. The owner says that model tractor gets lots of moisture in the hydraulics , and until it warms up , the hydraulics won't work. He says the high moisture problem is due to not having a breather for the hydraulic oil. Is this a common problem with the Farmall 560 tractor , or is something else wrong? Looking forward to reading replies. Scott Green
Post A Followup
: Re: Expert Opinion
