Re: 140 High Crop wide axle tractor
Posted by Hugh MacKay on March 14, 2009 at 02:30:21 from (216.208.58.118):
In Reply to: Re: 140 High Crop wide axle tractor posted by Joe1SD on March 13, 2009 at 19:26:43:
Joe: I believe the items you mention are aftermarket. I assume, quite similar to the extension used on a B or BN for rear axle. Front axle would be quite easy. I don't think IH did this. Probably someone mounting a harvester, I know Chisholm Ryder did a conversion on 140 for a cucumber harvester.
