Re: Implements for Farmall A
Posted by AGEN on February 07, 2001 at 13:32:33 from (128.194.22.55):
In Reply to: Implements for Farmall A posted by Keith on February 07, 2001 at 11:35:16:
Hi Keith. Don't forget that to use one of those aftermarket 3 point hitches, the trator has to have some type is hydraulic system, something a Farmall A does not have. (unless you are very inventive and add it.....the Super A has it) This means you can't use Fast Hitch equipment. However, around here (Texas) there is a good supply of old Farmall equipment. I have a set of 1 row cultivators, 2 bottom disc plow, two 5 foot discs, cornstalk chopper, lister plow, and a few misc. others. Most are cheap and if you're luck, you can find some in excellent shape.
Post A Followup
: Re: Re: Implements for Farmall A
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
