Re: Hydrolic lift problem/Gre-sen pump?
Posted by T_Bone on February 08, 2001 at 06:52:45 from (207.254.52.202):
In Reply to: Hydrolic lift problem/Gre-sen pump? posted by Kent Foster on February 07, 2001 at 12:21:10:
Hi Kent, You need to rebuild cylinders in pairs unless the one was very recently rebuilt. Although the one wasn't leaking on the outside it's probably leaking on the inside.
Pumps very seldom wear or fail. I would look esle where before condeming the pump. Also a pressure test would tell alot.
T_Bone
Post A Followup
: Re: Re: Hydrolic lift problem/Gre-sen pump?
