Re: Re: Need info. on IH corn planter
Posted by Keith Williams on February 08, 2001 at 13:59:42 from (208.22.2.4):
In Reply to: Re: Need info. on IH corn planter posted by Keith Williams on February 08, 2001 at 13:31:03:
Sorry mine is a 251 Planter not a 256
I e-mailed the SS to You.
If you can't read it, just create the following table in your spread sheet or use a calculator
(Wheel Circ / Driveshaft gear) *(Counter shaft input Gear / Counter shaft output Gear) * (Final drive gear / under plate gear) * (plate gear/ # of Cells) = distance between seeds in inches
To get
Population with 40" rows
With I3 being the distance between seeds
((6273/40)/I3)*1000
I have used the following settings the last couple of years
64" Wheel dia
11 tooth on Drive shaft
8 Tooth on Counter Input
10 Tooth on counter Output
10 Tooth on Shaft that drives planter units
12 to the 40 gears under the units
24 Cell Plates
6.4646 distance that seeds are apart
24,259 Population on 40" centers
The Spread Sheet formula for the distance between seeds is
=(A3/B3)*(C3/D3)*(E3/F3)*(G3/H3)
To get the Population with 40" spacing
=((6273/40)/I3)*1000
Hope this helps
Keith
Post A Followup
: Re: Re: Re: Need info. on IH corn planter
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
