Re: International 606 (TIMING?)
Posted by Lee K. on February 08, 2001 at 18:17:24 from (205.160.206.85):
In Reply to: International 606 (TIMING?) posted by Russell on February 08, 2001 at 17:30:05:
To set the static timming (time it with out engine running), put the engine on number 1 TDC. Turn the ignition on and put a test light on the negative terminal on the coil. Loosen the distrubuter and turn it until the light on the test light comes on. WHen it comes on, you know your points are open because electricitry takes the path of least resistence. When the points are closed, it is easier for the current to go through the points and to ground, and will not light up the test light. When the points are open, it is easier for the current to go through the test light, and thus, light up the bulb. When the light turns on, turn the distributer slightly against rotation, until the light just goes out. This will give you a small amount of advance. Tighten down the distributer, and make sure you have all the wires hooked up properly. Firing order is 1-5-3-6-2-4. It will give you a close guess on the timing. It'sclose enough to get the engine to fire. You will still have to do the proper timing when the engine is running, but at least you will know it will fire. I just did this on my 560. It fired right up almost instantly, and purred like a kitten.
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
